This AGM mystique is out of control. I have been reading all the posts and threads on AGM, and lots of “expert “ opinions and comments are just flat wrong, overcharging, undercharging, incorrect application, one post suggested reserve capacity was a smaller battery inside the battery. A lead acid battery is a plastic box filled with LIQUID acid, and AGM is nothing more than the same plastic box , they just soak the liquid acid in fiberglass cloth ( the acid does not destroy the fiberglass cloth) and seal the box. So they have the two dissimilar metals sandwiched in between the cloth instead of sloshing around in a tub of liquid acid.. In an Optima battery they just roll them up like a fruit cake instead of sandwiching them flat, basically a gimmick. The great thing about AGMs there is nothing to leak, or vent gas so you can use them in an enclosed compartment, you can even lay them on their sides. They have been used in aircraft for years because of this.
Here is the biggest misconception. There a basically 3 types of batteries, AGM or lead acid. A Start, dual purpose and deep cycle. A start battery has multiple thin plates that gives a large current draw for a short time. That’s why it goes dead if your truck won’t start after several tries. A deep cycle battery has really thick plates for a LOW CONTINUOUS DRAW, NOT CRANKING A STARTER! A dual purpose battery has medium size plates so it can handle a low continuous draw or a large current burst......hence the name Dual Purpose.
If you use a start battery, AGM or Lead Acid, in a deep cycle application you will drastically reduce the life of the battery.
If you use a deep cycle battery, AGM or Lead Acid, in a start application you will drastically reduce the life of the battery. Another issue AGMs are very sensitive to OVERCHARGING, 14.6-14.8 for a deep cycle charge 13.6-13.8 standby use. So the DC to DC chargers that are pumping 15 +volts are damaging the batteries.
Use the correct battery for the correct application.
