A topic has come up on another board about ABS and whether or not it should be disabled while off-road. I would love to hear what every thinks about this.
Steward I
So, specifically, you would rather be able to use the brakes to skid on command in a straight line, and not being able to do this feels like a second driver? I am not trying to pry--I really want to understand your perspective. But, it still sounds like you are describing some form of electronic stability or traction control, and not simply ABS.For me it is a matter of predictable versus unpredictable behavior.
It is as if the vehicle had two drivers, giving competing input into the equation. Sorry, but I would rather it was just me doing the driving. I don't need an electronic nanny.
ABS VS NON- ABS BREAKING
Anti-lock braking system (ABS) is a system that helps prevent the wheels of your car from locking, thus preventing your car from skidding out of control. ABS also allows you to steer your car while breaking strongly. In wet or icy conditions, where your car has less traction, ABS prevents your car from sliding and crashing as well as maintaining traction and allowing you to steer out of the way of obstacles. ABS has all of these many benefits however many car owners prefer braking without ABS.
ABS also has many limitations. On gravel or snow, hard breaking which causes the wheels to lock up is very effective as the locked wheels easily dig into the snow and gravel, stopping the vehicle. With ABS braking, however, the brakes don't lock up and stopping distance is therefore increased, causing the likelihood of a collision to increase. Some experienced drivers also dislike ABS as they know how to stop in an emergency without locking the wheels in an even shorter distance than with ABS. Some drivers complain that ABS sometimes activates when the brakes are applied very lightly if the car is on a bumpy surface. As most cars equipped with ABS do not have a function that turns ABS off, the people who prefer normal braking to ABS braking do not have the option of turning the function off.
I second the above, plus any kind of pulse braking on a curve on a surface with dicey traction is likely to be the last straw.ABS increases stopping distance. Period.
It's designed to maintain steering ability when the wheels lock up.
You should NOT have ABS when you are on gravel or sand or pretty much any other offroad scenario.
You need the wheels to lock up to push a mound of dirt ahead of you to stop sooner.... dig in so to speak.
ABS is really designed to be on pavement... and not in the winter time (in my opinion).
I'm saying having ABS still active when you are offroad is downright dangerous.Yup, ABS does increase stopping distance in low-traction situations--I dont think that was ever in question. I guess I must be a pansy because, like I said, I've never been racing around fast enough offroad to need to be able to skid to a stop :P .
*edit*
I also have to say I am very skeptical that your average driver would have been any more likely to save the day without ABS in your situation.
And, more generally, are all of you saying that the reason you dislike ABS is because of the increased stopping distances on loose surfaces?
I am a Mensan, with a physics background, to include teaching it. This is before I joined the AF as an officer, and before my 4 deployments and 1300 combat hours hunting bad people. I also recently finished a Master's research thesis. Most of my adult life has revolved directly around evidence-based pursuits and management of truth, so please don't presume you have any idea of what I am willing to accept, and what I am not.I'm saying having ABS still active when you are offroad is downright dangerous.
You don't have to be going fast to need to use the brakes and have them work. My example above was just 1 on-road example and my point was to be able to bleed more speed off prior to impact would have been nice. This was my most blatant example on-road I could think of.
I do all my offroading in 4Lo... so my top speed is typically 20 mph... and it's very rare to get going that fast even. My FJ is a big heavy beast and I have no interest in going fast in the rough stuff. The only times I get going a bit faster is on an actual gravel road and that's in 4Hi or 2Hi.... or one that at least resembles a road. I don't consider this actual offroading though. I've left my ABS enabled lots of times... and regretted it on more than one occasion.
ABS was never designed for offroad.
Toyota knows this as well.... that's why as soon as I go into 4Lo it's disabled. If it didn't do that I would have to figure out the wiring and install a switch myself.
There are times I've been out of the hard stuff on a trail, and the rest could be done in 2wd... I've aired up and drove in 2wd for the last bit of the trail. I would go over a couple nasty bumps and what Toyota calls "emergency brake assist" kicks in with only a minor brake application and you come to a skidding panic stop.... or ABS kicks in when I'm on the gravel and I can't stop when I want.
It sounds like you already have your mind made up and no amount of information will change it though.
To the OP.... get offroad and test it out for yourself if you need to. It will be very evident.
