Benefactor
I have started the suspension build with the strengthening process. As you can seen in one of the pics the sway bar mount is very weak. This causes it to flex when under load. While the product line I chose to go with is born in the rally circuit I can't help but believe the same pressure the suspension is under in a high speed corner or jumping would also happen at slower speeds with a heavy load and off camber on trails. I chose whittling to start off with. Their products are quality and well researched. I hope my build inspires others to go beyond the normal LP adventure or ADF lift kit and build your suspensions to last.
