2001 Land Rover D2
Lanlubber In Remembrance
Mimbres, NM, USA
covey sr
Reactions: Gabriel Bozeman
Mimbres, NM, USA
covey sr
Rte fabrication
I think I will make my own. Rte wants $800 + for a rear bumper. About the same for a front bumper as well. Thanks for the info on your rig build. I don't have a Discount Tire but I have a Big "O" tire center. I'll ck with them on the tires. Your tires are half the price of ones I have been looking at. Did you get 4 or 5 tires for that price.
MattAnderson1986
Off-Road Ranger III
3,785
Elkhart County, Indiana, United States
Matt
Anderson
I bought a lot of my stuff second hand and refurbished them. I also saved a lot by mounting the tires myself.
Mimbres, NM, USA
covey sr
I'm to old too do that any more , and yes you can probably add another $30 per tire for mounting and balancing at minimum.
I'm so old I have to call AAA to change my tire if I go flat in my driveway !
Mimbres, NM, USA
covey sr
I think we badly need a Craig's list specifically for Land Rovers of all sorts and years as a source of used parts. eBay is a rip off and I have never found a used part there. Maybe off roaders don't wreck their rigs HUH ? I've been thinking about opening a shop to fabricate bumpers and rock sliders for Discovery 1 and 2 series for about half the price the big guys are charging, mostly because of a much simpler design and a whole lot less weight. Not planning to get rich, just provide a product for the thousands of Disco's out there that are just now being converted from family transporters to off road vehicles.
MattAnderson1986
Off-Road Ranger III
3,785
Matt
Anderson
Facebook has a land rover parts page. also Dark Crow Designs makes affordable bumpers.
Mimbres, NM, USA
covey sr
Not sure if I missed this, but is your rear bumper an RTE? I'm in the market for a new rear on my D2, and really like the look of yours.
This drawing (rear bumper) is rough but if you take it to a local welding shop I'm sure you can have it made for half price. It is very close to what Matt Anderson has. I may draw his up just for fun, I like it too. If your interested I will send you a copy. Your welding shop can figure the best way to attach it to your vehicle, There are many ways. Fabricator needs to verify dimensions with your old bumper off. I planned to reuse my old bumper mounted signal lights, but you can change to LED lites if you like that better.
MStudt
Springfield, OR, USA
Studt
I'm sure I could make it cheaper than a local welder in my area. I work for a very large restaurant furniture fabricator, and have access to a full weld shop. I can take a rough drawing, and have my programming guys put it into a DXF file.
Mimbres, NM, USA
covey sr
The only dimensions that could be off is the one that says 66", It just depends on how much width you want. The other dimension would be from the rear of the bumper forward to the wheel well opening. I'm chopping off the bottom of the fender at the bottom of the 2" part of the side guard. I call for 2x4, 2x6 tubing with 2x2 on the side fender guard but "C" channel may be better depending on the abuse it gets. I will use "c" channel for the most part. wish I had your facilities. I will do it the hard way, disk cutter for shaping the steel and probably arc welding or flux core welder. If you make one post me a pic please.
Mimbres, NM, USA
covey sr
I may have a DX file on both front and rear "my kinda bumper" !
Mimbres, NM, USA
covey sr
Here is a good bumper build site on utube. excellent rear winch bumper but doesn't have to have a winch necessarily.
