1986 2F engine . Running engine with good compression 120-125 psi, uses 1 quart of oil every 1500 miles , Webber carb , 6 into 1 header exhaust. Alternator , distributor , igniter/ coil desmogged , newer factory OEM PSpump with 20000 miles on it, smog pump eliminator idler with spare bearing , factory air cleaner assembly. Well maintained in my rig for over ten years daily driver. Mileage unknown but shows 280000 miles on my odometer . Oil change every 4000 miles. 4spd h42 trans , shifts well and no bearing noise, Recent diesel and h55 swap. No equipment on site to load pallet .
Pick up in Albuquerque NM.
$ 750 engine
$ 350 For trans
$ 750 engine
$ 350 For trans
