Benefactor
- 15,584
- First Name
- Michael
- Last Name
- Murguia
- Member #
0000
- Ham/GMRS Callsign
- KM6YSL
The 11.12.0 Know Before you Go Release adds accurate 1:1 scale 3D map terrain detail to the map, seamlessly. It works with all route planning features so you can get an accurate view of the trail before you venture out! In addition, Offline Map areas can be adjusted prior to downloading and there are many other features and improvements in this major point release.
Release List:
Feature 3D Terrain on the Map
Feature Offline Map Download: Now area can be adjusted prior to downloading.
Feature Route Planner: Look into displaying Elevation Profile
Feature Ability for Users to Delete their Private Locations.
Feature Add a waypoint note field for route planning.
Feature Category Tabs on My Locations Screen
Feature Modal: Rank Increase and Trophy Awarded
Improvement Rally point dark mode calendar selector color
Improvement Rally point event offline map around gpx download needs 5 mile buffer
Improvement Basic stats in Map header elevation, speed, gps coordinates
Improvement Increase amount of time locations stay in "recent" searches
Improvement improve trail recording 'record' / 'pause' UI
Improvement Change “Save” terminology to “Bookmark” for clarity.
Improvement Track Download and Share Button label Changes
Improvement Map Download: Add Download Instructional Toast
Improvement Pop-up Toast with map Mode Change
Improvement Add "Map" button to the My Locations summary cards.
Improvement Time out temp pin creation in 5 seconds when offline - display whats available.
Improvement Switch to no tracking mode if map is panned.
Improvement Show total route length in route summary cards
Improvement Show my location when route planning
Improvement Tilt map when 3D mode is selected.
Improvement Refresh “My Locations” list after location delete
Improvement Add more obvious download region corner drag handles for map download.
Improvement Make tracks tappable (options?) to display summary card
Improvement When tapping a GPX attachment in messages and Forums, it will center on GPX during import step.
Improvement Quick-save icons do not scale up when highlighted (style POI do)
Improvement Add "Import GPX" to the Plus button on the plan tab
Improvement When user deletes a location, toast: This may take up to 36hrs to be removed.
Improvement Remove "+" Button on the Bookmarks tab.
Improvement Add "Quick Add" in POI summary card banner for "quick add" POI
Improvement Menu while downloading: Implement disable state + message.
Bug Follow filter in forums not displaying
Bug Gpx icon in pending upload does not properly center when trapped in map.
Bug Highlight states are not working in the edit resources map search screen.
Bug Mile markers not spaced 1 mile apart
Bug Rally Point Map centers on 0,0 instead of my location
Bug Lose ability to edit previous waypoints on initial creation.
Bug Real-time map header updates stop
Bug When selecting a search result from the list of map search results, no zoom in.
Bug GPX routes not displaying on map unless you tap POI icon.
Bug Color Picker Cancel and Change button does not show in landscape mode
Bug Dev - Record button: Fix Dark Mode
Bug Deleting any waypoint while route planning will crash the app.
Bug Permissions request during new user flow does not provide details.
Bug On rally Point Create, the invite map should center on start location
Bug Follow mode does not work
Bug Map message saying "Zoom In" event when zoomed in
Bug Followers list is empty
Bug Tapping a search result centers on my location, not POI location:
Bug Waypoint Note Improvements / bugs
Bug My Locations back button does not function
Bug Map does not center on locations correctly
Bug Following a share URL does not Open location until user goes to the map.
Bug Map displaying in perspective view by default.
Bug Images not being displayed in app on Dev.
Bug Forever spinner editing gpx off-road trailhead.
Bug Center on recorded track at zoom extents after saving
Bug No indication of downloaded map area
Bug Map search results returned off center
Bug Route saved offline (dev) disappeared from app.
Bug When offline, total distance says 0.00 when editing route.
Bug Summary Card says "1 Review" when there are 3 Reviews.
Bug Imported GPX file has no POI icon.
Bug Map won’t load after clicking location link
Bug If you tap another routes POI icon during route create, it will interrupt the route creation process
Bug Poi icon not changing to correct icon when resource type is selected:
Bug Message GPX attachments won't open in OB1
Bug Tapping follow in followers list results in black screen
Bug Tapping a download in the offline maps list does not center on download area.
Bug POI icons not showing in search results.
Bug Create Rally Point location placement
Bug Rally point dark mode calendar selector color
Bug Rally point offline map icon formatting - white space
Bug Rally point event offline map around gpx download needs 5 mile buffer
Release List:
