Pioneer I
So here's the diagnosis. Lifter for cylinder 6 intake valve seems to have had something chew through it, probably a needle bearing, though I didn't notice any missing. So the lifter is shot as well as the camshaft.
Fortunately everything else looks OK. The pushrods look fine, as does the bore for the lifter. I pulled the rear 4 pistons out and the bearings all look fine and there is minimal scratching on the piston side walls. The cylinders don't seem to have any scratches in them that a hone wouldn't clean up, I couldn't catch anything with my fingernail.
All in all I think it's in great shape other than the lifter and the cam. I'm probably going to put a mild cam in to give it a little boost, seeing how I have to replace it anyway. New lifters and pushrods will be cheap insurance. I'm going to inspect the rocker arm that lifter mated with to make sure nothing went through it and chewed it up as well.
Hopefully I can get the rest of it torn apart, cleaned up, and then put back together in the next couple weeks. With how minimal the damage is I think it's definitely an attainable goal.
