![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nprotector1.png)
Protector I
- 13,461
- First Name
- Bjoern
- Last Name
- Eldracher
- Member #
20111
- Ham/GMRS Callsign
- DO3BE
I don't like it at all when things and equipment tumble around loose in the car. On the one hand, you can't find a lot of things when you need them, and on the other hand, it can be dangerous. I prefer to have everything handy and yet well secured.
Now I have some pens, pencils, text highlighters, very simply attached and yet they are easily accessible. Taken an old broken tire tube from the motorcycle, cut a slice and fastened it so that the rubber is somewhat under tension similar to a rubber band. I was able to easily attach the piece around part of the cockpit trim. The pens, pencils, etc just clamp underneath. Cheap, just a little time and works easily and well. Keep it simple.
By the way, I have seen such a simple solution before in a fire department command vehicle.
![20221109_160141.jpg](/forums/data/attachments/247/247379-d62273dea384aacf9915c4a7353ef0ad.jpg)
