Water in the Roof Rack
Adventure Dave
Morro Bay, CA, USA
Dave
Gravender
I had a need to work on my Smittybilt SRC Roof Rack on my TJ. When I took it off there was a significant amount of water that was in the rear uprights. That conerns me a bit from a rust perspective as the water was quite brown when I poured it out. Has anybody else drilled some weep holes in the bottom of the rack to allow this water to escape?
Reactions: SubeeBen
S
SubeeBen
Guest
Haven’t taken the rack off of mine but now you have me wondering as I have the same rack on my Jku. Should be an easy fix though as you stated with weep holes @ front & rear upright mounting points. Thanks for the post. & of course it’s pouring rain in San Diego today. Ha ha.
Adventure Dave
Morro Bay, CA, USA
Dave
Gravender
I looked at the front and it is open at the bottom so not a problem. The back is sealed after the curve. I’m driving them out this afternoon. Rained here this morning so I’m sure I’ll find water in there.
Adventure Dave
Morro Bay, CA, USA
Dave
Gravender
I just finished making the weep holes and indeed there was water in the rack. It turned pretty brown at the end so I’m sure it was causing rust on the inside of the pipes. I took a video but can’t seem to figure out how to post it here.
S
SubeeBen
Guest
Lovely. I opted to mount my rack using the body mounts so I’m just going to drill some weep holes & should be good. FYI not sure what size holes you drilled. But in my line of work anything less than 1/4” will not allow water to exit. Surface tension. Kind of like when you can fill a glass to the point of overflowing & the water holds to the point when it is actually higher than the top of the glass. If that makes any sense. But I know for a fact anything less than 1/4” will not drain.
Adventure Dave
Morro Bay, CA, USA
Dave
Gravender
I emailed Smittybilt about it. They said a few customers have had the same issue. They suggested drilling a hole and hitting it with some paint.
