Ok so ive been trying to find a truck bed rack for my titan. I don't and can't spent the $$$ for the top name ones but I've found a brand that should work. My question is...Does it matter that much about having a longer rack then a shorter one? The static weight for both sizes are the same. Only difference is the dynamic weight. For my truck, I have the 6'5 bed. The smaller rack is only right at 41 inches long and the other is 57. As for mounting items I will probably only mount my high lift and a couple tools. Most everything else will be in the bed of the truck. Theres almost $130 difference between the two and delivery options are better on the smaller one. Just wondered about yalls input and if anyone else has run a small rack like that on a full size truck. Thanks in advance.
