Stokes Nomad inductive cook system
Soapy
USA
Frank
Gray
After waiting many months for the Nomad cook system to arrive I am very happy with the quality. It has a 9 inch fry pan and a 2 liter boiling pot. I tested it and it will boil a liter of water in 6 minutes. It uses a reactor plate and each pan has a built in inductive sytem for even heat. You can set it to use between 200 to 1000 watts which makes it very friendly for on board car inverters as well as power banks. Non stick coating on the pans and comes with a single lid and a very robust detachable handle. Only short coming I can see is that it did not come with a pack bag,
Reactions: Blu12T and Kent R
Executive Director
Any chance you could post some pictures, I am curious about this.
Reactions: KonzaLander
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
Ragman
Geneva, IL, USA
Richard
Gearhart
Looks like a neat system. I am curious though if you have, say a 400 watt inverter, can you still get the pan hot enough to sear?
Soapy
USA
Frank
Gray
I have not used mine yet but my son did get out last week with his and cooked up some steaks and made some cobbler in the pot and said it worked very well. Very easy to clean also.
Soapy
USA
Frank
Gray
Stokes reached out to me and they are sending out a carry bag to be included with their systems. You can sear at 400 watts but it does take longer. The pot will bring 2 quarts of water to a boil in about 3 minutes using the 1000 watt setting.
Reactions: danwyandt
Soapy
USA
Frank
Gray
I used it on a recent trip when there was a wood or propane ban due to fire restrictions. It worked great to cook bacon and eggs and used the Stokes kettle to make several pots of coffee. Great small footprint it worked great.
