Wanted [Seeking 2019 4-Runner parts] [Located in So-Cal IE] [see list, shocks, UCA, LCA, Rock sliders, front bumper ect.]
sharktooth49
Claremont, CA, USA
Andrew
Fernandez
Fmf corpsman
Looking to buy items below for a 2019 5th Gen 4 runner trd offrd w/ KDSS
*Skid plates
still need front, mid, rear, fuel tank, lower control arm skids (NEEDS TO BE KDSS or cheap enough I take out my grinder)
*LCA
Only lower control arms and hubs, not replacing UCA thank you
*Front bumper
C4 Low Pro or similar (similar in brand/style not a high bar thank you)
*Rock sliders (low profile, no step preferred)
*rear bumper. Low profile
*********** PURCHASED THANK YOU ****************
*Wheels
Method 315's in gold (purchased)
*UCA
Kibbetech Toyota 4 Runner 03-19/ FJ 07-14 Upper arms × 1 (purchased)
*Gold King 2.5” coil overs front 2.5” rear
* Camburg 1.5" Rear coil spring kit × 1 (purchased)
* Toytec front diff drop × 1 (purchased)
* Toytec Rear bump stop drop × 1 (purchased)
* KC M-rack with Pro 6 light bar.
* 8 panel switch pod
* ARB air compressor on rago mount
*DRT fab body mount relocation
* DRT fab spindle gussets
*dometic 45L with insulation & slide
Should be relatively easy gear to find with a ton of shops to choose across the West Coast and South West. Your location puts you practically in the heartland of most of those companies directly. Not sure if you're specifically looking for new or pre-owned gear but (?) Should be a nice build in the end
Reactions: sharktooth49
