Samsung tablet for Gaia ? | OVERLAND BOUND COMMUNITY
Discussion in 'Overland Navigation' started by Boots, Feb 11, 2019 at 9:33 PM.
  1. Guest, Did you know you can change the look of your Overland Bound forums? At the bottom of this page look for the Style Chooser! All previous and new light and dark themes are available. Pick something you like!
Hi Guest, Become a Member to gain access to the Member Forums, Member Map, Member Calendar of Events, and Rally Point overland trip planner! Click this link "Learn More" for more information!
  1. Boots
    Boots Rank I
    Central New Jersey
    Map
    #1 Boots, Feb 11, 2019 at 9:33 PM
    Ok all, I am as dumb as a brick when it comes to using a tablet for onboard Navigation. At this time I am using a Jeep Trail Guide for Nav it's made by Garmin (it can also be used as a handheld). It works great and also has topo, but the screen size is way to small. Looking at picking up a Samsung model tablet and using Gaia. What would the best Samsung model to pick-up for this use ? I really like to stay with Samsung because I can buy any Samsung Phone, Tablet, or Laptop at 15% above cost......
    Hank Outdoors likes this.
  2. Boots
    Boots Rank I
    Central New Jersey
    Map
    #2 Boots, Feb 11, 2019 at 9:39 PM
    Also, am i going to need a external ant. or anything like that to pick up Sat signals with the Samsung ? This is going into my 08 Jeep Wrangler......
  3. Hank Outdoors
    Hank Outdoors US East Region Director
    Staff Member Moderator Member
    Lysander, NY
    Member #:
    9435
    Map
    I was running an old Galaxy Tab 10.1" for Gaia in my FJ. I loved it but it was pretty old. The Sat worked great on it and never had any issues and never needed an external ant. I switched to new Android model which is much faster but not as nice as the Samsung...I may switch back. LOL
  4. RedBeard
    RedBeard Rank III
    Vallejo, CA, USA
    Member #:
    8896
    Map
    I have a Samsung Tab 8.0 currently in my rig. The only issue I've had with Gaia has been downloading maps. Not sure if it's an Android only issue, but both my Samsung tablet and phone have download issues. When I attempt to download maps, each tile takes forever and downloading a 100MB map will literally take overnight... assuming the download doesn't fail.
  5. Hank Outdoors
    Lysander, NY
    Member #:
    9435
    Map
    They take a while on iPhones too...
  6. Chris Jones
    Chris Jones Online Community Director
    Methuen, MA
    Member #:
    0520
    Map
    I have the Samsung Galaxy Tab A (2017) no cellular. Was cheaper by a bit to go with the lower storage (had a micro sd to expand storage) and no cellular. If I need to download or connect to internet on the go I turn on the hotspot on my phone and connect to that. Then I don't need to have a data plan for the tablet. GPS seems to work the same on this as other tablets I've used.
    DirtyPenguins and Hank Outdoors like this.
  7. Hank Outdoors
    Lysander, NY
    Member #:
    9435
    Map
    I do the same with the hotspot.
  8. MaTacoma18
    MaTacoma18 Rank 0
    Florence, KY
    Map
    I can't get my Samsung to charge in my truck. Anyone else have issues?
  9. Boots
    Boots Rank I
    Central New Jersey
    Map
    #9 Boots, Feb 12, 2019 at 10:57 AM
    Chris and Hank, your about to see how dumb I am on this stuff. When you say, you need to hook up to a "Hot Spot" does that mean you would use your 4G on your phone for internet, then run some sort of cable (maybe a usb or something) from your phone to your tablet ? And would you do this in real time, or download info from the internet to your phone first and then transfer the info via cable to your tablet ?
    The Samsung tablet I was looking at is a new (refurbished) Samsung S2 with 64GB, Wi-Fi, 9.7" Screen. Processor speed is 1.9 gigahertz, GPS Enabled, Bluetooth Enabled, Expandable Memory SD, Adobe Flash Compatable, and System Memory (Ram) is 3 gigabytes..... My cost on this s2 would be $126
    DirtyPenguins likes this.
  10. Chris Jones
    Methuen, MA
    Member #:
    0520
    Map
    I can set up a WiFi hostspot on my phone. Then I just connect to that hotspot (wifi signal) with my tablet like I would if I was at home. no cable required. The phone uses the cell network to offer interent connection.
  11. Boots
    Boots Rank I
    Central New Jersey
    Map
    Ok, I think I understand better. It's like when I am out on my Harley and I get a phone call on my phone it will come through my Nav screen saying I have a call, no cables... One is talking to the other. I think it's called Bluetooth.
  12. Chris Jones
    Methuen, MA
    Member #:
    0520
    Map
    similar, yes. do you have a router at home, that gives off a wireless signal you connect to with your devices so they can access the internet? It's that exact thing except your cell phone is acting as the router, and your tablet is connecting to the internet via that connection.
  13. Boots
    Boots Rank I
    Central New Jersey
    Map
    yes I do Chris, I believe I am starting to understand how this works. So their is no need for a data plan for the tablet then. It's basically that the tablet is a big GPS unit. Now for the next question, for the most part it would be best to load up any maps that may be needed before starting on my trip ? In other words, If we are headed out to Moab, UT. for Jeep Safari I could download my route out with any sidesteps we may have planned, and then also download any trails we are doing while their. Then if their would be any changes in either routes I could create a "Hot Spot" with my phone and make any necessary changes to my Gaia maps at that time...
  14. Chris Jones
    Methuen, MA
    Member #:
    0520
    Map
    There are a couple limiting factors to using your phone as a hot spot. Your phone needs to be able to offer a hot spot. And your data plan has to have hot spot / tethering enabled. Some plans don't allow it.
    Yes, to your other thought. You want to have the map tiles downloaded in advance. They download pretty slow over anything less than LTE.
  15. Boots
    Boots Rank I
    Central New Jersey
    Map
    Ok Chris, thanks for all the information and patience. I will check on my phone plan and see if tethering is possible... I get my Samsung stuff from my son's employer, he said i should see it by the end of next week. Next will be a mounting system and getting set-up with Gaia....
Share This Page
