2007 FUSO 4x4 OVERLAND FOR SALE
Located in Salt Lake City, Utah
Designed for global travel in tough environments having everything you need while still a manageable size. This 4x4 with locking hubs and 19.5 inch rims means it can go anywhere you can imagine. Fully insulated aluminum cabin with a shower, toilet, hot and cold water, air heater and 120v inverter. It is ready for your next expedition.
Built to handle very low temperatures with the whole water system inside the cabin, fully insulated and with a diesel air heater, it has been used down to -17F comfortably. The vehicle only requires diesel and fresh water to operate. If you are look for a go anywhere vehicle on multi week trips that can still fit in a regular parking space this is for you.
As an avid explorer myself, I have taken it across the Mountain West on back road trails in both summer and winter, and it has never failed to impress me. Now, it's time for it to embark on new adventures with its next owner.
Mechanical:
- Mitsubishi Fuso FG 140 4WD 2007 (pre-DEF)
- 4.9lt Turbo Diesel
- Fully maintained with 162k miles
- GVWR 14,050lbs , curb weight wet with full tanks and expedition supplies 10,300lbs.
- 5-speed manual transmission with high and low gears
- 4 wheel drive
- 19.5 inch super single wheels on Toyo M608Z tires
- Locking front hubs
- 3 seated cab
- Replaced cab A/C compressor
- Upgraded 2 chassis batteries
- Variable front bump stops
- Over cab platform for storage
- 8 spring subframe to allow full articulation
- Full body paint in 2024
- Back storage compartment is full width and height to store bikes, skis or totes
- Pull out quick access steps and larger collapsible steps
- Tow package with 2.5” receiver
Cabin
- Cabin is a military S-744/TSM-191 V shelter full aluminum outer and inner sheeting around an aluminum frame which is thermally isolated. With 2 inch foam core on all walls, floor and ceiling. Exterior dimensions of the cabin are 12ft by 7ft.
- Full shower
- 5kw Diesel air heater
- Thetford C403L cassette toilet
- 84 gallons of fresh water
- 11 gallon grey tank inside for insulation
- Seaward 3 gallon electric water heater with a thermostatic valve
- Arctic Tern windows with blackout and mesh and the door are all insulated
- Fantastic fan with temperature control
- Electric Isotherm 65 cruise fridge 2.3 cu.ft.
- All Victron Energy components
- 2000 Watt multiplus inverter for 120v supply
- 200 Amp hours of Battleborn batteries
- Charges from the trucks 100 Amp alternator
- Seating for 5 people, converts to a queen bed
- Full kitchen cabinetry with large sink and butcher block countertop
Mechanical:
- 4 wheel drive
- 3 seated cab
Cabin
- Full shower
