RTT and Roof Weight Limits
Atx353
Hey y'all. New guy here from MN. Looking at getting a RTT. My question and concern came when I spoke to Tepui about their 'Lightning' hard-shell tent. They said that I would need a bar system that allowed for 195lbs. After further research it seems my vehicle—a 2015 Jeep Grand Cherokee—has a roof weight limit of 70kg's or roughly 155lbs. I was recommended to reach out to 'Rhino Rack' and inquire about their heavy duty bars that can hold 220lb. From what I understand, even if the bars can hold a higher capacity, the weakest link (my roof's capacity) is the strongest part. They also said that if the roof can hold '155lbs' I would have to subtract the weight of the roof bar system ~10lbs from the capacity, leaving me at about 145lbs. The hard-shell RTT's I am interested in are exactly 145lb, and some are 165lb. So, I have a few questions for y'all who are probably much more knowledgeable than I:
1. I've seen quite a few people with RTT's on their vehicles, is it safe to say that most are pushing or exceeding the dynamic weight capacity? Would going over 20-30lb's cause issues?
2. After doing more research, some of the research suggested getting rid of the factory flush mount, and bolting in directly a 'roof rack' from for example, Gobi. Gobi's roof rack shows a 300lb dynamic weight limit. However, since it bolts directly into the roof, wouldn't it have the same '155'lb limit?
The rep at Gobi stated that, the rack actually increases the limit since it's not the actual roof that has a limit, but the factory flush mount. So, clarification/affirmation on this subject would be helpful, since if the rep was right a roof rack would provide a good piece of mind as to not be maxing out the roof's limit.
Thank you!
Captain Chaos
No
No
No
I’ve always thought the rack was the wea link, not the roof itself. At 155lbs, it wouldn’t take much to crush a roof.
Welcome to the forum! I was born and raised in Mora MN.
GPsGeeps
I have heard of a few people sustaining damage to the area around the front roof mounts. SO FAR I haven't had any issues with my Tepui RTT and Front Runner Slimline II rack. I've used it a handful of times without issue. But that doesn't mean the same thing won't happen over time to mine. I think the consensus is that Gobi and Uneek are the two racks out there that offer the most support for heavy loads for our WK2's. But Chief Products has just announced their new rack if you can wait until the end of the year. They claim 150kg static and 600kg dynamic!
https://www.chiefproducts.com.au/products/wk2-roof-rack
