BNIB Smittybilt 2781 Heavy Duty Air Compressor Kit. Purchased it as a Christmas gift for my Dad as I have the same one on my truck. I didn't know he had already traded for a VIAIR 300P and didn't need this one. Below is the information from Smittybilt.
For the added convenience of being able to air-up or air-down your tires to accommodate various types of terrain, a Smittybilt Air Compressor is the most powerful compression unit in its class with a 1/3 horsepower oil-less direct drive motor and a 30 amp inline fuse.
- Easy twist screw-on brass inflator top.
- Quick release 24 foot coil hose for the 2781.
- Anti-vibration rubber feet.
- Can be permanently mounted and hard-wired.
- Auto-thermal cutoff switch -- protects motor against damage.
- Built-on cleanable airfilter
- Storage bag included
- Maximum airflow -5.56 CFM /160 liters per minute
- Maximum voltage - 13.8 volts
- Maximum amperage draw @ 120 psi -45amps
- Maximum restart pressure - 150 psi
- Maximum operating temperature - 140 deg F
- Minimum operating temperature - 4 deg F
- Maximum continuous cycle time (Duty cycle) - 40 minutes @ 40 psi @ 75 def F
- Integrated 150 PSI - Easy to read pressure gauge
