Roof top wiring?
Odgunrunner15
04010
Just wondering how everyone is wiring their lighting, etc. on the top of their rigs? I would like to set up a multi circuit system to power separate banks of lighting and power to my rtt. Is there a company that makes a multi pin water tight connector? Thanks
4xFar Adventures
Benefactor
4,826
San Francisco,CA
Brenton
Corns
For my set of 4 roof rack lights, I use x2 4-pin trailer harnesses. The outer lights are on one circuit, and the inner pair on another. Two + and two - wires on the harness makes a perfect fit. I also connected opposite ends of the harness to each circuit so they don't get mixed up.
Reactions: Odgunrunner15
Knitron
US Rocky Mountain Region Local Expert Utah
Clearfield, UT
Jason
T
KJ7EBG
I run a 12 gauage + & - lead into the tent through the hindge area. Inside it splits off to a flexible led bar and a pair of USB ports. It connects with a Delphi weather pack connector at the end of lead so it could be used somewhere else. I use Delphi weather pack connectors on all the exterior led lights on my trailer.
Sent from my SPH-L720T using OB Talk mobile app
Vyscera
Chico, CA, USA
Smith
Delphi, Deutsch, mulitlock, molex all make weather resistant connectors, and are prevalent in cars, trucks, and motorcycles. If a connector works 5" above the road totally exposed, roof applications should be easy.
Odgunrunner15
04010
Thank you for offering your input everyone. I think I have found exactly what I need with your suggestions.
