What is everyone using to adhere their patches? I have the Mopar headliner kit and its more like a fabric than plastic like the Hotheads. Just double sided tape? I would think after enough time in the heat they would just fall off.
If your patch already has the hook side of the velcro sawn onto your patch, it will stick to your fabric headliner. If not, sew the hook side on to patch so you can take patch on/off or rearrange. They won't fall off. If over head not fabric then yes use sticky side of velcroOK, maybe I am not following. So you all use Velcro which has tacky on both sides plus Velcro sandwiched in the middle rather than just two sided tape? I will give it a shot - have a bunch to pin so will try this weekend. Thanks all.
Going to try this later.The newer Toyota’s have a less sticky headliner. My 17 Taco and our 19 4Runner have semi smooth liners. Although with a little persuading you can make them stick by pushing them flat with your palm and giving a few slight twist back and forth. My collection is small and aren’t really “overland” patches but I just started in this soooo
Traveler II
