Respooling a winch
trekwithsly
Mississippi, USA
Sly
Vawj
I installed a winch a month ago and I've tested it in the field to get an idea of how to operate it safely using a tree saver, soft shackles, etc but when it comes to respooling, is hand tightening "good enough"
I'm running a synthetic line and don't have the means of another car to help with natural tension when respooling. Any tips or tricks would be appreciated. Thank you!
MMc
San Dimas, Ca.
McMullen
I needs to be tight or it will pull the line into the spool. I pull mine with the Parking break set a little bit. Use a tree or something strong.
Sebt1890
Louisiana, USA
Sebastian
T
This, I used a tree, made it taught, threw it in neutral and got it tightened properly.
