Recommendations
A.C.Ambrogio
New Jersey
Andrew
Ambrogio
Hey everyone. I'm just looking for some recovery gear recommendations. I'm thinking about the weekendlander ARB one. Also any suggestions on onboard air? I'll probably get ARBs as well
K12
Endurance III
5,786
Idaho, United States
Beau
K12
Air Force
ARB is a great company. I have a set of their recovery boards as well as the dual air comoressor hard wired in with a quick hose disconnect at the rear license plate. With the recovery kit, just make sure that the weight rating on everything in the pack is high enough for anything you may use it on (may not be your vehicle if you need to help someone).
Reactions: A.C.Ambrogio
Owen Sound, Ontario, Canada
James
Girard
I'll say what everyone hates to hear lol. I have found smittybilt products to be fairly decent.
When it comes to recovery gear everything needs to meet standards and be rated properly, which means that for someone starting out smittybilt products can be a great entry level setup. That being said, will they last as long at other brands? Probably not.
When it ones to air it's kind of a crazy shoot. You really need to dive into cfm values and ratings and what pressures they rate them at. ARB compressors are much nicer and easier to mount than pretty much anything else, and rates their cfms at a higher pressure than most, but I have seen a lot of issues with solenoids when running lockers ( not personal experience just have a buddy that seems to blow through them all the time and we can't seem to figure out why). If you don't need a lot of air then there's not a whole lot of sense ( in my mind) in spending the money on an ARB compressor if you're only filling stock size tires.
That's my long winded 2 cents.
Oh and don't ever uy smittybilt traction boards... they suck.... I have a set and though they are rated for a lot of weight they will flex and buckle if you try to use them as a ramp or anything bridging any gaps. They don't have the versatility of other traction boards... oh and their winch anchors don't anchor as well as others lol
Countryboy20241
Taylorsville, IN, USA
Russell
Woodhouse
I use a smittybilt winch and love it, have had them for a few other rigs.
Reactions: Red_Leaf_Overland
