Hey OB folks, I'm looking for your first-hand experience with an Overland trailer. I'm currently kicking-around the idea of an overland trailer for use with my WJ but would love some real world feedback.
My rationale for a trailer is as follows:
So, OB:
Thanks for any input and advice!
-TJ
- The WJ is a great, relatively small size - but that means less storage space than say a JLUR and more importantly it's just not going to work out well for me to sleep inside
- With sleeping inside mostly ruled out, I started thinking about RTTs, but I think I'd only consider a hard-shell (for a few reasons, mostly just that soft-shells look like a PITA to cover/uncover and setup... especially being about 7' in the air if it were on my Jeep). With the WJ being smaller most hard-shells are too big for it, leaving really only the iKamper SkyCamp Mini (which is a definitely an option for me) but even that is still going to be way up in the air
- I've built my WJ with a very flexy, somewhat long-travel (at least compared to stock, it's no Trophy Truck or anything) suspension. This is great for offroad performance, but has the downside of not making it ideal to put a heavy hard-shell RTT on top of, nor ideal for over-loading the back with too much weight
- Maybe I just want one because they're darn neat... lol
- With the ground tent I need to find and clear a good, relatively flat spot
- Setup and breakdown are more extensive, which is not really a big deal for staying in one spot, but not awesome when moving daily
- The tent I've been using doesn't retain heat well, tent options that do retain heat well are way bulkier and would take up too much space in the WJ (and take even longer to setup/breakdown)
- If you arrive at camp in inclement weather setup is no fun (same for breaking down camp)
So, OB:
- Have you overlanded with a trailer?
- If so, do you still use it?
- If you stopped using a trailer, why?
- What did you like about having an overland trailer?
- What didn't you like?
- If you were buying again, what would you do differently or change about the trailer itself?
- What type of trails and camping did you do with your trailer?
- Were there situations where you found the trailer limiting you?
-TJ
