Pioneer I
So this weekend I picked up what will be the start of an overlanding/camping trailer to pull behind my H3. With myself, my wife, and three growing daughters (currently one is 10, the other two, twins, are 7), camping has turned into an ordeal with barely fitting everything in/on the H3, even with a hitch cargo rack in addition to my roof rack. Plus it's a pain having to spend a couple hours getting everything loaded up whenever we want to go camping, so we tend to not go very often. My goal is to build an overlanding/camping trailer that we can leave packed with the majority of our gear so then all we should need to do is get clothes packed, throw food in the fridge, hook up and head out.
Here's how it sits right now. It's a M101A1 (I think, no build plates on it that I can find), I picked it up for $250.
As you can see it's not the prettiest thing ever, and frankly it's worse than it looks as far as the tub goes. Lots of rust through at the bottoms of the stake pockets, the tailgate is pretty messed up (seriously, I have only a vague idea how they could have bent everything in at least three different directions), the floor is pretty dented and is rusted through in a few spots on one of the bottom supports, The rear tub uprights were cut through for the taillights, the tires need replacing, the wiring for the lights is half missing (the middle half for some reason, the lights have wiring and the trailer connector to hook to the vehicle is there, but nothing in between that) and the eye bolts for the A-arm are missing.
But, all that being said (plus some unsaid things), the positives are that it's already had the axle replaced (and has electric brakes, not sure if they actually work though, but still), the bolt pattern matches the H3 wheels, the frame is in really good shape other than some surface rust, and I got it for cheap. Really, for $250 the frame alone is worth that to me. I considered building my own frame and everything from scratch, but it's so much simpler and less risky to use a good solid frame already made for me.
As far as the tub goes, I will probably repair it enough to use in the meantime as a regular trailer (we're going to be moving this summer so it will help with getting some stuff up to my wife's parents who live near where we will be moving to) and for camping possibly. But the reality is that I will probably end up scrapping the tub unless I find the repairs are going better than anticipated. Really the tub seems to be pretty darn heavy, so replacing it will be a better option anyway since then I can make it a bit lighter and tailor it to my needs and wants. I'm not going to war with it. Hopefully...
The axle seems to be in good shape overall, I had the seller pull the bearing caps off and the grease looked and smelled fine, though one side had some play in it, but that looked like it just needs the axle nut tightened properly. There are not any shocks on it currently, and there is nothing for the bottom shock mounts on the axle unfortunately, but that's not hard or expensive to fix. The upper shock mounts look fine.
As for the missing eyebolts for the A-arm, the eyebolts used for the tailgate hinges are the same, and since the two inner hinges aren't even in use right now (because it's so bent up they don't align anymore) I'm going to pull those off and use them for the A-arm to get that bolted back into place, instead of the lame bit of wire that's holding it in place right now...
The trailer pulls well though, I didn't notice any issues with tracking, and backing it up wasn't too bad, especially considering I rarely ever pull a trailer. I think this will make a great foundation for an overland/camping trailer. Be forewarned though, it's probably going to take me a couple years before it really becomes anything since I'll only be doing modifications as I have time and cash, but I'll make updates as I go.
