hi All,
This seemed the most appropriate forum for my question, apologies if not: I have a '15 Outback which I've got lifted, and am doing a custom top rack platform for, under armor, the like.
Which brought me to a battery setup. I need a battery setup that will meet the following requirements:
Has anyone used a Northstar marine "dual" Starting/Cycling battery? Any specific recommendations for configuration?
If you had enough electronic gear (including specialized batteries!) that you needed to charge that was sufficient to completely drain even a group24 over a week, and you wanted to charge from the vehicle if possible... what would you do?
External power packs that aren't integrated into the vehicle's systems aren't useful to me in the context of this discussion. I know they exist and will use them as appropriate.
Thanks!
- Allow me to charge fairly large batteries for production equipment in the wilderness
- Later, allow me to power a simple HAM setup
- Support a fridge, if I go that route
- Allow me to use a fairly simple solar panel charge setup for longer trips.
- Prevent me from draining the starting battery through normal use
Thanks!
