not tacoma specific, as mine is in an AEV Prospector, but i had my viair dual compressor + tank mounted to some sheet metal, along with the gauges, fuses, regulators and an anderson connector. it simply sits in the bed and is easily removed if i need to put something else in the bed OR, if i want to let another vehicle use it, or use it from my trailer, etc. the only thing i installed in my truck, is a cable from the batteries with an anderson connector on it, so i can hook it up whenever. i also have a cable with anderson on one end and jumper cable style clips on the other, so i can run it off the starter battery of any other vehicle without mods.
