Asking $7,300
- Includes Kamper 4 person tent (includes wheel every weekend security mounts)
- MAX COUPLER ARTICULATING HITCH
- Full brakes with brake pads (including emergency brakes)
- Box is constructed of 14 Gauge steel laser cut and CNC bent
- Frame is 2x3 .125 wall rectangular box tubing.
- Cargo box dimensions 72 inches long, 26.25 inches tall. 50 inches wide at the top and 40 inches wide at the floor. 46 cubic feet.
- Overall length is 141 inches
- Overall width is 64 inches
- Frame and body are powder coated (some custom colors require automotive grade spray process)
- Raptor liner is sprayed inside the tub. (linex or rhino lining is an option at an additional charge)
- Trailer can accommodate up to a 37 inch tire.
- 2 inch hitches are utilized at both ends
- Nose box included + Cargo box (used for fire wood)
- LED brake, turn and marker lamps
- Axle is rated at 3500 pounds and has electric brakes (tow vehicle will need a brake controller installed)
- Multiple wheel bolt patterns available
- Lid is supported by 3 heavy duty hinges and also features 2 gas struts to aide in opening.
- Latches are lockable. Includes two load bars to support a tent.
- Drop tail gate for easy access
- Power tank propane gas holder + 5lb propane tank
- Water on board powered by USB Pump
- Includes 3 trailer jacks (one with wheel)
- Includes 4 chocks
- Includes 4 chocks
