night photography question regarding film vs digital
JimInBC
Southern Vancouver Island
Freer
Reading 2 of the threads here regarding night photography got me to wondering.
I have not done any long exposure work with my digital and so some of my work flow for long exposures is film driven. I thought I would start the question here. In film there is the issue of reciprocity failure during log term exposures, failure point can vary between different film. But basically it results in the need to have a longer exposure than the metered EV would require to get accurate colour exposure on the film.
Is there anything like this with digital sensors? Or is it just noise I need to worry about?
Boort
Colorado
@XJinBC
I have not done any long exposure work with my digital and so some of my work flow for long exposures is film driven. I thought I would start the question here. In film there is the issue of reciprocity failure during log term exposures, failure point can vary between different film. But basically it results in the need to have a longer exposure than the metered EV would require to get accurate colour exposure on the film. Is there anything like this with digital sensors? Or is it just noise I need to worry about?
On modern sensors reciprocity failure is not generally an issue. Even my old Nikon D700 is fairly linear. Meaning if you double the shutter open time you can close down or lower the ISO setting by 1 stop. This holds true for even my longest exposures. I've done many at ~30 Mins and the math holds true at least that long. Astro-photography is sooooo Much more fun with Digital than it was with film. Higher ISOs are still usable, 6400 and higher depending on Camera. Feedback is nearly instant so you don't lose a night of sleep and $50 on developing due to some bad math or trying out a new film.
Boort
SW_UT_FJ
Hurricane, UT
Russ
Wright
KA7HOS
@XJinBC
Boort
Well put, great information!
Reactions: Boort
JimInBC
Freer
Thanks. This is what I assumed but, you know where that can get you sometimes. Digital makes learning and testing a whole lot faster.
@XJinBC
Boort
@XJinBC
Boort
Reactions: Boort
btedesign
Lakeland, fl
Andrew
Sardone
Night time Photography is awesome. I became so obsessed with it at one point it was all I did. Digital is the way to go with this, the ability to have the shutter stay open for an eternity and know you are not going to be burning through film and time (maybe time) due to a small settings error. As far as reciprocity failure, I agree with @XJinBC you won't have an issue with digital. Even in today's smaller compacts, the sensors are built well enough you won't have an issue. Post some of your photos as you get up and going. Good luck!
Reactions: JimInBC
