So after doing lots of research I decided to pull the trigger on an MORryde tire carrier and remove the one I have had for the last 5 years. I must say this kit is amazing! However I found out some great information from this install.
I wanted to share that with this system if you have a 1.25” body lift you will be able to run a 35” tire with no offset brackets!
Check out this video I made to see!
Heavy Duty Tire Carrier Kit
