To answer your question you could install an antenna switch to choose which antenna you want to use, just make sure they are mounted far enough apart as to no cause interference with the other.mainly curious they both seem to have different uses short range vs long range etc. I am running a 3db one now but have a 6db but have not had a reason to use it yet. Was thinking if I have both then you would have both uses on hand but may not really made sense.
On flat ground the 6db can still talk short range so you wouldn't benefit from the 3db antenna in that case.
The below image may help show a use case for each antenna.
