Mechanical question...I am stumped. Looking for insights into this engine issue
Adams
My friend has a 2009 jeep patriot for a cabin rig. He parked it after using it fine all weekend, went to start it the next weekend and it sputtered and just shut off and would not start. Been through the entire electrical system etc. The funny thing is that it seems to have compression when the plugs are out. put a drop of oil into the cyl and crank, it will shoot the oil back out of the plug hole, but when the plugs are in it's like it has no compression. Any help to diagnose this little rig would be helpful. I am thinking either head gasket, timing is jumped somehow. The gasket would show signs of leakage, as would a crack in the block etc. It really got me stumped
thanks
Murphy Slaw
Southern Illinois
The Patriot does not have a timing chain.
So it's not that.
How many miles?
We swapped ours after 165,000.
I was actually more concerned about the sealed transmission (6 speed) which was flawless the whole time.
North American Sojourner
Inventor I
3,886
Mid-Missouri, MO, USA
Dave
Zimmer
USN (ret)
Mice? What are the codes? Have the battery checked. You have to ask yourself what changed since you "drove the car" to the stopping place? How did the compression change in a week? Battery health is very important to a car that has several "modules" to keep the car alive.
Just because the motor turns over doesn't mean it will stay running.
Hope it gets fixed.
Zim
cody92595
Arlington, WA
Dakota
Howard
Check basics. If it sat I’ll bet there’s a mouse nest in the air box. No air, no start.
Ontario California
SMR
KO6BI
Retracted my diagnoses.
As everyone said.
Start simple.
Major mechanical issues give you strong symptoms with clues leading up to them.
Psfracer
Santa Clarita, CA, USA
Paul
Fercho
If something didn’t eat some wires - then use KISS method. Engine needs air, spark, fuel. If its getting air, take a spark plug out and keep it hooked up the the ignition wire. If you have spark, then its fuel. I vote fuel pump.
Reactions: madcratebuilder
Flamewave
Oakdale, CT
Matusiak
I vote fuel pump.
Quite possibly that or fuel pump relay. But crank no start situations can be tough to diagnose with all the electronics in modern engines getting in the way.
Anecdotally, my buddy's '06 Ferd Exploder is going through a similar thing. It seems to be getting fuel, air and spark but still won't start, after replacing damn near everything we could think of we had to admit defeat and send it off to the shop. I mean we tried cam sensor, crank sensor, fuel filter, fuel rail pressure sensor (definitely getting fuel pressure at the rail, found out the not smart way :sweatsmile:), new plugs and coils... Codes said it was rich one cylinder and lean on another, it'd start and run for two seconds very roughly after sitting for a day and then not start again and that's all we had to work with, then it refused to throw any codes at all after the battery died and was replaced. I think it's either timing or VVT-related but we didn't want to pop the valve covers off to replace the VVT solenoids and called it quits at that point.
Pretty sure it does.
Reactions: TexasLandman
