Support Alert created at 10:07 PM (GMT +0:00) on 05/11/2024 by Anna (Anna_XJ98).
Additional Information
Important links:
Locations included in the Support Alert:
Location 1:
Communications Channels included in the Support Alert:
- Address: A86, Newtonmore, PH20 1BX, United Kingdom
- 3WA: ethic.voice.engages
- Phone:
Dear community, I need your help. We have arrived Scotland.
Just one day and approx. 300m we are stuck again after the last fix on the ignition coil. The vehicle was running fine until we stopped for a short break, when trying to start it again we have following situation again:
It is a ´98 Cherokee XJ 4.0 wich does crank but does not start.
We do have fuel pressure but no spark indicating that there might be a problem with the crankshaft position sensor, cam shaft position sensor or the ignition coil again.
We would like to give it a try with a new crank shaft position sensor, 56027866AE, cam shaft position sensor 56027023 or the ignition coil 56028172.
See also the picture as there are different plugs availabe depending on the fabrication year.
If someone would have any of those parts we are very happy to get in contact and buy those.
Does anyone know how to get quick help so that our vacation doesn't go to waste? ❤
Important links:
Location 1:
Coordinates: 56.95140, -4.49612 (lat/lng)
Location note:
