...and what terrain, and what purpose, and your experience level, and your intent.Quick answer is no, and the second is a question of vehicle and axle.
Along the same idea of vehicle specifics, installing lockers into a stock discovery 1 or 2 is risky business, if you bind up one tire and give it all the torque of the engine in low range it can, and will, snap an axle shaft. So in addition to adding in a locker all the axle shafts should be upgraded to HD shafts etcYou haven't specified your vehicle type. If you're running a JK model Jeep your vehicle has BLD, which stands for Brake Locking Differentials. These work awesome, so if you had them and you were an Overlander I would tell you lockers aren't required. Your vehicle might also have a limited slip differential, so check about this first.
If used incorrectly lockers can cause damage to your vehicle, so unless you plan on rock crawling or traveling through a ton of wombat holes lockers are not necessary.
Unless you want to dig a 4ft hole and put your spare tire into the ground. But you make a very good point on winch vs locker.Also on the note of a winch though, keep in mind a winch is only as good as your anchor Point, so if you are planning on heading to a desert or planes without trees or rocks it would probably be wise to invest in a land anchor
Sent from my Nexus 6P using OB Talk mobile app
Which is when you would need them most anywaysA little info for you non-Jeepers. The lockers on a Rubicon only work in low range and below 14 Mph. Self installed lockers will work beyond those parameters....
