I have a 2017 ford F1 50 that is Stock. I would like to do moderate off-roading, nothing too crazy. Should I go for a 2 inch level with slightly bigger tires or a 6 inch lift much bigger tires?
Glenn,I have a 2017 ford F1 50 that is Stock. I would like to do moderate off-roading, nothing too crazy. Should I go for a 2 inch level with slightly bigger tires or a 6 inch lift much bigger tires?
Then run it like it is, unless you need a little more room in the front for a bigger tire. On my last few trucks, I would run the leveling kit in the front, then add a 1" block or add-a-leaf in the rear the get back just a touch of rake. Gave me room for a larger tire, and a little more ground clearance, without losing too much of the factory suspension geometry.I actually don’t want a lift. I just didn’t know if I needed one.
Glenn, one more thing.I have a 2017 ford F1 50 that is Stock. I would like to do moderate off-roading, nothing too crazy. Should I go for a 2 inch level with slightly bigger tires or a 6 inch lift much bigger tires?
I think you will be pleased with the look of the meatier tires. KO2s are a SOLID choice, great tire. Can be had in a C load to keep weight down too. A 2" level and those tires will completely transform the look of the truck while keeping the MPG just a mile or 2 less at the most.Thank you. This helped a lot. After reading this I knew what to do. So this AM I pulled the trigger on a 2 inch level with fox 2.0 coil overs, changed my rim from 20 inch to 18 inch for more side wall. Got maverick 18x9 rims with 33 inch K02 tires (33.2x10.8).
Next, I need skid plates.
What you are building will destroy any fire road I've ever seen. You should be good to go.I am nervous going down fire roads. Trust me I scare easy. I get mad if I even see a little scratch on my truck lol.
