Installing fixed solar panel
diabetiktaco
Local Expert New Jersey, USA
Marlboro Township, NJ, USA
Eric
Beauchea
I've got a Zamp Obsidian 100W kit. Has anyone installed something similar? I want to make sure I'm heading in the right direction before I get started..
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I basically followed this video for my 100W fixed solar setup. My panel is attached to one of my roof racks and goes into the bed of the truck where the battery, inverter, and charge controller are located on a board similar to what's in the video? Does your kit not come with a charge controller?
diabetiktaco
Eric
Beauchea
Well I had to get it separately but I do have it. I have a tacoma so I figure it makes the most sense to mount the controller and panel readout in the bed somewhere and run the other wire to the battery under the hood.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
If you're just going to charge your main battery, then it would be easier to put the controller inside the truck and run the wires through the firewall? Just gets more a little complicated if you're charging a secondary battery in the bed of your truck.
diabetiktaco
Eric
Beauchea
I have to experiment. Maybe I can run it behind the back seats.
GreyMudder
Saint-Louis de Kent, NB, Canada
Rino
Granito
I would want my solars not attached, but on mounts where I can position my solars to the declination of the sun. Solars will degrade at an alarming rate when not in direct sunlight , a simple shadow can degrade performance by 50 % or more. but just my 2 cents here.
diabetiktaco
Eric
Beauchea
I have two portable panels as well. The fixed panel is really just for trickle charge and situations where I don't want to put the portables out.
GreyMudder
Rino
Granito
What controller are you using ? do you have a DC to DC charger with Solar input. I think you can put a soft panel on roof top but a good controller and charger is a must. Are you going with Lithium Iron Phosphates batteries . I trying to work out a cheap way of maxing out Litium Iron for all of my needs with a good setup. Even thinking of wind turbine for long stays and a dump charge on my fridge freezer.. but its only conceptual at this time. Opps sorry not meant to hijack..
diabetiktaco
Eric
Beauchea
Going w/ the Zamp weatherproof one. It's all going to a Bosch AGM 94R 80AH battery.
1Louder
AZ
K
K1LDR
Renogy panel. I have the controller mounted on my transmission hump on the passenger side. I had to run the wires through the firewall there. Too many already going through the drivers side. :) Some day I will probably redo all of that and run the wires through the roof but that is a big project with pulling the headliner down and doing things properly. My controller has an optional Bluetooth module, also by Renogy, that lets me look at the stats via my phone which is nice.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
How is the recharging time and how much capacity do you normal extract from the batteries ?
My understanding is that the higher capacity panel the faster the charge. Depends on size of your battery as well amperage-wise?
