How to hold a handheld HAM securely in the rig
El-Dracho
Ambassador, Europe
Supporter
Off-Road Ranger III
13,288
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
Hi!
Beside the permanently installed coms I use also a handheld. Have a charging cradle for it with a cable which plugs into 12V.
Currently I am thinking about how to hold it securely in the rig. My favourite would be if it sits in the charging cradle. But how to mount this. Maybe someone has an idea here or have implemented it this way already.
Thanks,
Bjoern
1Louder
AZ
K
K1LDR
Ram Xgrip mount. I have one mount to where the grip handle is supposed to be on the driver side of my FJ. Lots of mounting options. Xgrip holds it well. It’s where I keep my phone but is also strong enough to hold a small handheld.
Reactions: El-Dracho
peeeeetey
Harrisburg, NC, USA
Pete
Meuser
GMRS WREL270
I have thought making a holster out of Kydex and some how rigging the contacts in the bottom of it that correspond to the contacts on the battery. I still am thinking where and how to mount it.
Downs
Hunt County Texas
Joshua
Downs
KK6RBI / WQYH678
USMC 03-16, FIRE/EMS
I'm not sure how you would go about securing the radio to the charging base effectively in the vehicle. I know Motorola makes a few in car solutions for charging but it's Motorola so $$$$$$
Looks like someone does something for Yeasu as well.
Not sure what kind of radio you're trying to secure but maybe you could use an existing charging base with a strap like in the above solutions. If it'a baofeng type not sure if that would work since they ride so loose in their charging bases.
peeeeetey
Harrisburg, NC, USA
Pete
Meuser
GMRS WREL270
I have a Baufang uv 5
El-Dracho
Ambassador, Europe
Supporter
Off-Road Ranger III
13,288
Bjoern
Eldracher
DO3BE
... I like the idea with the tie down strap - will try it! Thanks! If it works properly I will share some pictures here :smile:
It is a Yaesu FT-4XE I have.
Cheers, Bjoern
Reactions: Downs
El-Dracho
Ambassador, Europe
Supporter
Off-Road Ranger III
13,288
Bjoern
Eldracher
DO3BE
Not sure why it says I am a guest but I have been a member for years
Yeah looks good. I like that idea! So do you just fitted the RAM ball to the original holder?
Rose
W7FSB
US ARMY Retired
I use this
Rugged Radios MT-5R Single Side Radio Mount for Baofeng, RH5R & RDH Handheld Radios
holds my HT really well... I have several more on order to add HT mounting solutions to other projects I have.
