Even though you have an inverter in place, the best and most efficient method to power the Dometic and to give you most piece of mind (particularly in warm environments) about not killing your cranking battery is to add another battery, a deep cycle one, and run the fridge via 12v from that.
Nowhere near as efficient in the long run to convert the 12v battery power to 110 for the inverter.
You can get a very inexpensive battery isolator that will allow you to charge the extra battery while driving but isolate it from discharging the cranking battery while stopped.
There's a
short vid on amazon that recommends hooking it to 110 in your house just to get it down to temp. Then run it from 12v in your vehicle.
The advantage of having a second, deep cycle, battery is that you can then run a fuse panel from it, and use that to run other 12v and USB outlets, etc. so you're not continually deep discharging your cranking battery. It's not meant to do that and will die prematurely.
Good luck; it's all pretty simple and makes good sense, really, once you get into it.
Roaddude - Traveling Photographer/Writer/Artist On the Road In North America. Gear, reviews, people, places, and culture.
roaddude.com
