Hi all,
I am thinking of buying a hard shell rooftop tent for my Suzuki GV XL-7. The thing is, the standard roof rails have plastic feet which are probably not strong enough to carry the weight of a tent plus inhabitant(s). For that reason I am considering to remove the standard roof rails, and see if I can get a custom made solution using steel parts only.
The XL-7 will not be used as a daily driver, so the tent can remain on the vehicle. Basically, all I need is two cross bars to fit the tent onto, what I am not sure about is this. The studs used to secure the roof rails to the vehicle - which I will need to use for mounting the custom made cross bars - are 140 cm (55 inches) apart front to rear. I've seen many rooftop tents fixed onto no more than just 2 cross bars, but usually the longitudinal distance is less than that. The question is whether the frame of a rooftop tent is rigid enough to bridge that distance without bending too much.
Obviously, hard shell tents come in different qualities, but hopefully some of you can comment on this from their experience. I would be very interested to learn about your observations on this issue.
Thanks and regards,
Frans
Thanks and regards,
Frans
