This rig needs to be on an adventure!!!
Looking for that perfect rig for overland travel?
This is a rock solid, PROVEN set up with fewer electrical components to troubleshoot
It won't break the bank and will take you just about anywhere you can imagine going...
You've found your UNICORN!!
*Willing to separate*
$55,000 USD - OBO-
You won't find a better deal on a solid set up like this
Please inquire for individual prices
2021 Off Grid Trailers Expedition 2.0
Towed by a
2005 Toyota 4Runner Limited 4x4
V8 (2UZ-FE)
Miles: 13X,XXX (these engines known to go 500k+ miles)
Automatic Transmission
4 Wheel Drive
Current location: Santa Fe, NEW Mexico, USA
NO ACCIDENTS, CLEAN TITLE in hand
THE GOODS
Truck Details
Non smoking vehicle
2021 Off Grid Trailer Expedition 2.0
Specs
TRUCK
Rock solid and no known issues - mechanical or otherwise - except as stated here:
• Typical Toyota clear coat cracking, fading, and peeling, particularly on the hood and in a few other areas. - Price reduced in consideration
• Body is in excellent shape! Some minor door dings and scratch on rear passenger side but no dents and no accidents.
• Some surface rust on underbelly - nothing corrosive and none on the body
TRAILER
Rock solid and no known issues - mechanical or otherwise - except as stated above
Anything else you want to know, any other photos or video - please ask.
Thanks for looking!
$55,000 USD - OBO-
Towed by a
V8 (2UZ-FE)
4 Wheel Drive
THE GOODS
Truck Details
Non smoking vehicle
- Routine maintenance following Toyota service guide
- Timing belt replaced at 92k miles
- Transmission: Automatic
- Manual Transfer Case - Full-time 4WD, 4WD LOW, Locking Mid Differential
- Fuel: Gas
- A/C: A/C blows cold!
- Heat: Toasty Hot!
- Custom cargo area drawer storage
- Full Monstaliner on exterior surfaces
- Alu-cab tilting fridge slide
- Airline style tie downs (L-Track)
- Locking drawer slides rated to +300lbs
- Driver side drawer (20Wx36Lx11D)
- Dometic CFX3 55 IM
- 12V Auxiliary Renogy Hybrid GEL, 100Ah
- Redarc Dual Input 25A In-Vehicle DC-DC Charger
- Solar input routed to rear bumper
- Lighting on inner rear hatch door
- 100 Watt solar panel
- 22-Inch 2-burner Partner Stove with wind guards
- Secondary drawer for prep surface and additional storage
- Spare Tire Swing - 80% Off-Road
- Power Tanks 5lb propane bracket
- 5lb Manchester propane tank
- Trasharoo
- Low profile winch mount -Lost Trail
- Warn VR Evo 12-S
- Factor 55 - FlatLink - WLL 16,000lbs
- Sherpa Equipment Company Roof Rack - The Princeton
- Load Rating
- 300lb Dynamic
- 600lb Static
- Shovel mount
- Antenna for Midland GMRS
- 100 Watt solar panel mounted
- Load Rating
- Suspension Upgrade
- 2” Fox Suspension Lift Kit Front and Rear
- Total Chaos Upper Control Arms
- Heavy load springs rear
- AIr bag load assist
- Auxiliary Systems
- ARB Twin Air Compressor
- Air chucks in engine bay and at rear of truck
- Redarc Tow-Pro Elite Electric Brake Controller
- Fire Extinguisher - H3R HalGuard Clean Agent Automotive w/ Seat mount, located on passenger side seat
- Long Range America - 24 Gallon auxiliary fuel tank w. Transfer pump and dash mounted level indicator
- Custom dash bar for mounting RAM mounted iPad
- Midland MXT275 MicroMobile
- Wheels and Tires
- ProComp 34 Series Rockwell - 17” (to match trailer allowing more emergency spares)
- Falken Wildpeak A/T AT3W 255/80R17 E-Load
- Factory Features
- 2” Rear Hitch Receiver
- 4 and 7 Pin Trailer Harness Plug Connector
- Power Windows, Mirrors, Door locks and Driver and Passenger Seat
- Heated front seats
- A/C and Heat work perfectly
- Cruise Control
- Interior Dash Digital Temp Sensor with average MPG
- OEM heavy duty rubber floor mats (front and rear)
Specs
- Dry Weight: 1700 LBS
- Tongue Weight: 290 LBS
- MAX GVW: 3500 LBS
- Departure Angle: 50 Degrees
- Ground Clearance: 21″ | 25″ w/ Evolution Series Suspension
- Overall Width: 89 Inches
- Overall Height: 79″ | 83″ w/ Evolution Series Suspension
- Wheelbase: 120 Inches
- Track Width: 76 Inches
- Interior Headroom: 46.5 Inches
- Interior Length: 80 Inches
- Interior Width: 56.5 Inches
- Fresh Water Capacity: 31 Gal.
- Mattress Size: Queen
- Rear Exterior Cabinets: 15″x27″‘x56″
- Interior Cabinets: 28″x14″x56″
- 360 degree Maxcoupler Hitch (Receiver and Tow vehicle adapter)
- XO Jack
- Independent Timbren Susspension
- Furnace (6500BTU)
- Dometic CFX3 55IM
- Maxxfan Deluxe 7500 fan upgrade (thermostat, electric lift, remote)
- Spare tire mounting plate
- 11lb Propane Cylinder
- On demand hot water heater
- 23Zero Shower stall
- Matching Flaken Wildpeak A/T AT3W 255/80R17 E-Load
- (3) 100 Watt Solar Panels (300 total watts) with Zamp port for additional panels
- Battle Born 2 x 100Ah 12V LiFePO4 Heated Batteries
- Redarc Dual Input 40A In-Vehicle DC-DC MPPT Charger
- Victron Energy BMV-712 Smart Battery Monitor
- Terrapod RTTx XL clamshell style tent
- Exped Megamat Duo 10 (trailer cabin) and DeepSleep Duo 7.5 (RTT)
- Overland Pros Wraptor 270 Awning - Passenger side
- Front Runner Pro Stainless Steel Camp Table and Mount
- Lifetime adjustable height table
- Partner Steel 18" 2 Burner Propane Stove With Windscreen
- Custom spice rack in galley
- Custom under sink/stove dish drying rack
- H3R MaxOut Dry Chemical Automotive Fire Extinguisher w/ Extreme Duty Mount
- RLD Design Lion Boxes (rebranded frontrunner boxes)
- Custom blackout insulated window coverings
TRUCK
- Interior is in good shape with the exception of driver seat cover tearing.
TRAILER
Thanks for looking!
