DIY -Lights mounted to DIY roof rack
Rokketz
Prosper, TX, USA
Chuck
Washburn
KI5ATP
Looks good! How'd you route the wiring? Switches? Relays?
wired all 4 together on common run, with a relay and mounted switch inside on center console just to the right of the AC controls.ran the wire through the channel in the roof rack down through back hatch (under weather stripping) then under trim panels back up through firewall so i could connect directly to primary battery.
Reactions: Lincoln7
diabetiktaco
Local Expert New Jersey, USA
Marlboro Township, NJ, USA
Eric
Beauchea
Those are actually decent lights. I use them for scene lighting under my tent on my roof. The harness that comes w/ them is solid too.
