So I had some mounts fabricated by a guy on a 3rd Gen 4Runner board for my new hi lift that I like to refer to as a Spanish Inquisition Device.
You remove two tie downs just inside the lift gate and put in the mounts et Viola. BUT, I have caveman-like mechanical skills, I broke off the screw. With a trip coming up, a new idea is needed.
What do you think? I have a small basket rack. My plan is to cut and attached foam pipe insulation and put them on the rack, then use 3-4 points to lash the jack with a steel/wire rope that's dipped in vinyl. Think mega twisty almost as thick as a bike lock chain.
So it seems like an ok idea to me, and the cost is less than 10 dollars. I doubt I'll need it the jack too often, but I like this better than just laying in the back.
Thoughts?
SLO Robert
Thoughts?
SLO Robert
