This project is for a 3rd Gen 4Runner, but I think the concept could work for many vehicles.
Supplies:
The 22 ga steel can be cut with tin snips. I won't say easily, but it can be done.
Bending the metal this way doesn't get you a perfect bend, but it's good enough.
TIP: The 3M tape is BURLY and will leave residue that's hard to get off. The dark rubbery 3M tape is insane and a pain in the butt to get off which is I why I use the white stuff. They don't even usually sell the dark tape in the stores, but it's what comes on most adhesive mount items like phone mounts, GoPro mounts etc. I suggest getting some 3m Vinyl film and putting it down first and sticking the tape and velcro to it. It's designed to come off at some point and should not leave any residue or destroy things when you pull it back up.
Here's the support brace. This is where I used the velcro so that I can get the center stack face plate off.
Here's an image of it in use with the iPad Mini 4 mounted up running Gaia GPS. Works perfectly!
-M
Supplies:
- 22 Ga Steel from Home Depot
- 3M tape (The white stuff)
- 3m Velcro
- Tin Snips
- Angle metal and clamps
- Grinder, files, sand paper
-M
