Digital inclinometer
TxJeeper75
Steward I
4,392
San Antonio, TX, USA
Heiman
KI5LHN
I have been using the same style inclinometer my grandfather had in his bronco back in the 80's. Not sure how accurate these really are. I was thinking of upgrading to a digital version, but am unsure of a reliable brand. What types are you all using in your rigs, if any?
JacksonRL
Educator I
5,533
York County, South Carolina, United States
Jackson
Lewis
USMC
I think it’d be neat to have one of those. My truck has the readout on the dash. I think it comes with the fx4 package. Not sure. But, not sure how accurate it is either.
Reactions: Desert Runner
Coreymol
Local Expert, Texas USA
Guardian I
14,980
Boerne, Texas, United States
Corey
Molinelli
WREM781 on GMRS
Army
this is my inclinometer...not particularly accurate, but HIGHLY sensitive and its audible alarm signals an immediate end of the ride
Haha this is great. I just realized I generally have two with me. One passenger side. One back seat
MOAK
Donald
Diehl
WRPN 506
I had one of those ones with the steel ball back in the late 70s. I ended up tossing it. 15 years ago or so, I used one on my phone app, cute, noisy little monkey. I deleted it. The very last thing anyone should be looking at during extreme technical driving is their dashboard.
Ubiety
Sammamish, WA, USA
Greg
Ubiety
Ribs
I tried an app for a very short time and found that this particular app drained the device's battery fast. I am also constantly bumping my phone/tablet which means the app is never zeroed correctly. My current truck has a built in inclinometer, from the factory, which is great and all but I never look at it in tense situations. Maybe the best inclinometer would retain a log of "extreme" angles with GPS coords for review afterwards.
Edit - Hmmm, sounds like a fun project! I already have a GPS connected ras pi running in the truck and a very accurate accelerometer just sitting here. Could merge those together to allow the ras pi to collect logs of angles and lat/lons and then post process said logs into a color coded KML. The KML would not only provide a track of my travels but would color code the track to show angles at a glance. Hmmmm.
MOAK
Donald
Diehl
WRPN 506
Yikes! That’s one heck of a hobby you got there. Lost me with ras pi LOL !!
rgallant
British Columbia
Richard
Gallant
VE7REJ
RCAC (Reserve) 75-00
@Ubiety and you will share that code :grinning: - it would fun a picture in picture with dashcam footage.
I use the old feels good must be ok system.
Reactions: Ubiety
Ubiety
Sammamish, WA, USA
Greg
Ubiety
Ribs
Agree with seat of the pants; I always try to figure out what the pilot is doing on commercial flights with my butt ;)
But instrumentation and colorful tracks on the map are cool too! ;) Sure, if you are interested I would share. I should have time to get to it in 2025? ;)
Reactions: rgallant
Ubiety
Sammamish, WA, USA
Greg
Ubiety
Ribs
The accelerometer that I originally planned on using for my "vehicle tilt logger" did not work out. Received this one last night and am easily getting data out of it. Will post more info once I have something working in the truck. At the rate that life is going recently that should be in early 2025 ;)
Rose
W7FSB
US ARMY Retired
The old analog inclinometer is more accurate than anything digital can provide. The reason being the old school inclinometer is a pair of weighted disks suspended in liquid, and works off of gravity alone. Digital inclinometers use magnetic sensors to gather information of how lev the vehicle is. These sensors can be influenced by other magnetic fields, metal, and even types of terrain that have natural magnetic fields. The sensors then send data to an electronic device that has to calibrate said sensors, calibration makes the sensors less accurate in itself. To calibrate an analog inclinometer the device just needs to be set on a level table to get base adjustments, then when mounted in the vehicle on level ground you adjust the mounting base until everything meets the base adjustments. Yes more work, but 0% loss in efficiency.
Ubiety
Sammamish, WA, USA
Greg
Ubiety
Ribs
MEMS accelerometers are made from silicon and not subject to magnetic fields, etc. Just waved some strong magnets around my new accelerometer and it was not affected. Once calibrated they should not need to be calibrated again.
