Cookware that stows well?
wahoowad
Virginia, USA
Wilbur
McGee
I use this compact GSI Outdoors Glacier cookset as a holdover from my backpacking days, and while it is a quality stainless cookset that packs away easily in my storage box (which I like a lot) I am now often frustrated with it while overlanding because I have to keep using that fiddly pot gripper. I now want a similar sized cookset but something with handles that makes it easier to use on my Coleman stove or firepit grill.
I do most of my main dish, meat or vegetable cooking on my cast iron pans so just need a replacement cookset to boil water and cook things like rice and pasta. Any suggestions? I still want it to pack as small as possible but I can accomodate some helpful handles now that i am not a backpacker. I'll always have the Glacier system when space truly is at a premium.
adventure_is_necessary
Lucas
Antes
KE0ZXA
This is what I use from Stanley. I like having all of the bits packable. I am able to store some items inside of it since I don't use everything included all the time. Granted, this replaced using normal kitchen cookware, but I like how it is still versatile enough to use in the kitchen both at camp and at home (which I do). While I love my cast iron, I can say I'm good with cooking on this kit at camp. Hope this helps! I honestly started with my backpacking/bikepacking setup to begin with, but when I added in more people, the kitchen cookware was a must until we could figure out a replacement.
MMc
San Dimas, Ca.
McMullen
I have used these for years, you need to watch the heat on the handles but they work great. 20 plus years on the set I have. The handle are always fixed. I can cook for up to six with my grill or frypan all day long. The coffee cup is a measuring cup.
Reactions: RSmothers45
1Louder
AZ
K
K1LDR
I have been looking into this set. It's pricey but looks bomber. Anyone here use these pans?
I got the non-induction set for my birthday. I added the storage bag. About as compact as you can get. Expensive but also well made. If you can afford it go for it! I have only used it on one trip but more will be forthcoming. Being able to remove a handle on a pan makes all the difference in compact storage. I still carry a cast iron pan but I am trying to make all of my gear more compact. If you don't care about that there are lots of cheaper options with traditional pans. Green pans are good.
Reactions: Minjin
Rose
W7FSB
US ARMY Retired
Have you looked into the GSI Basecamp Cookwares?
Reactions: RoarinRow
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
I'll second this recommendation, although, it may be bigger than you're looking for. The big pot is probably 10" or so. Then it has bowls, plates, silverware, spatula, serving spoon, and another pot inside.
TerryD
Covington, Virginia, USA
Terry
R
KT4OZ
We have a MSR Alpine pot we've been using to go with our cast iron pan. It works great. We also keep a small GSI S/S cup in the kit that I use to drink my coffee or do small amounts of sides like green beans or chili for hot dogs.
m_lars
Heber City, Utah
Matt
Larson
KJ7ATX
I use the GSI Pinnacle Camper for the family. It works very well. It's compact and stores well in my kitchen box.
We also use the GSI Pinnacle Camper set for backpacking when we're out as a family and really like it. My only complaint (as with any light weight cooking gear) is the thin bottom has hot spots and can scorch things easily. We also added the Crossover Kitchen Kit which packs in the middle in place of 2 of the bowl/cups.
I have not used that set, but have only heard great things about it.
Reactions: Stumpalama
m_lars
Heber City, Utah
Matt
Larson
KJ7ATX
Has anyone here used the STANSPORT - Heavy Duty 7-Piece Stainless Steel Clad Cookware Set? The description reads like it's similar to the Magma set, but not near as expensive.
The other Sean
Minneapolis
I have the same one and like it. I have swapped out the sporks for better (MSI?) units. This and a small cast iron pan and I am GTG.
Lucas
Antes
KE0ZXA
I have some titanium sporks that we use instead of the plastic ones. I would prefer all metal (either titanium or food grade stainless) to be able to do the boil cleaning method I used to do when backpacking when a dry clean wasn't easy. But it works. I tend to try to make meals that are easy to cook and easy on cleanup if it can be helped.
Trillium23
Kingman, AZ, USA
Joseph
Stevens
KD7WGU
I use the Magma set in the 4runner and Snow Peak when the JK goes out. Magma set is great but a little on the heavy side.
Truckee
Bay Area, CA
I have the Magma Ceramica set. Great quality. I don't normally use non-stick at home but quick cleanup with little water won out for the outdoors.
cyrus799
United States
Cyrus
Juliet
We recently purchased a STANSPORT cookware set and are very pleased with it. The set comes with a detachable handle, which is initially for the frying pan. Completely nested, causing the entire set to take up little space.
