Hey y'all we're new to RTT life and wanted to find a way to mitigate condensation that isnt overly expensive. Any tip/tricks or gear advise would be greatly appreciated. Thanks!
.Hey y'all we're new to RTT life and wanted to find a way to mitigate condensation that isnt overly expensive. Any tip/tricks or gear advise would be greatly appreciated. Thanks!
.I had a problem with condensation underneath the mattress during cold weather. I don't think it had anything to do with tent ventilation per se since I leave plenty of ventilation because I like it cool being inside a warm bag. I think it was the warming of the mattress from body heat and the cold from the air outside on the floor causing moisture to form between. The higher humidity down here probably exacerbates the the problem. Probably not so much in the desert @Road . The moisture that can form inside the walls and ceiling can be from not enough ventilation and moisture from breathing, temperature differences, etc. I understand this since the Boy Scouts a hunnert years ago. I think we are dealing with two different situations.
At first, I was in denial that moisture under the mattress was a problem. Then I found the moisture after a couple of cool 30 - 40 degree nights. So, I purchased a not inexpensive anti-c mat that was made to fit and fold with my brand RTT. $130 or thereabouts. I did find some cheaper alternatives mentioned that were a type of filter mat? available from the hardware store that looked like it may work. That would require cutting and taping and there could still be an issue with folding it. Velcro might help hold it in place. I think mine came with Velcro? Anyway, to get the underneath the mattress ventilated so as no to trap moisture is a little expensive and it should be sold with the RTT, IMHO, because if one camps in cooler weather it may be a problem in my experience. Ventilation is a good thing! Funny how they never mention the under mattress moisture when selling you a RTT.
Off-Road Ranger III
20111
According to the title of the topic, I assume that you are specifically looking for something for under the mattresses, right? When researching roof tents more intensively, I have seen a kind of mesh material that is available as mattress underlays. This provides better ventilation and thus the removal of moisture. Side effect is a certain insulation effect and a comfort gain especially with thinner mattresses. The material is available from the roll and can be cut individually. These mats are certainly also available in the U.S. at the outfitters, I guess.Hey y'all we're new to RTT life and wanted to find a way to mitigate condensation that isnt overly expensive. Any tip/tricks or gear advise would be greatly appreciated. Thanks!
