Check your bolts that hold the bed on the frame. this week i kept hearing a clunk when hitting bumps i figured it was where my exhaust tip rubs my rear shackle its normally just a squeek but i thought maybe something shifted i checked and things were the same so i got in the bed and started making the suspension cycle to see if i could replicate the sound, no luck but as i was getting out stepping off the bumper i had weight from my arms on the bed and it made the noise. So i checked the bolts holding the bed to the frame and sure enough the one on the front passenger side was nearly falling out, I tightened it up and no more clunk. So check your bolts folks especially if you go off road often. We go on some pretty rough trails so i figure it worked its self loose on the rocks bouncing around, so this weekend ill be going through every bolt on the truck front to back to make sure they are all tight, if you offroad often you probably should too.
