![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/ntraveler3.png)
- First Name
- Lucas
- Last Name
- Antes
- Member #
7082
- Ham/GMRS Callsign
- KE0ZXA
I was recently given an old "milspec" Coleman Leaded Gasoline lantern, produced in 1963, which is the 252 model from what I understand. Anyone have experience rebuilding and maintaining these? After some cleanup, lubrication, and fresh fuel, she will not flow any fuel through. I'm holding some pressure in the fuel tank as it does release some when opening the fill cap or the pump valve. I imagine the seals are too dry and worn for the lubrication to help. I know I'll need to acquire some replacement seals and such but also will need to find out how to maintain it as well. I have a soft spot for these old Coleman camp products as I have a 1971 425E that I've used one my overlanding trips, as well as a backup in case of emergencies. I was looking for something to match or at least be older and run off the same fuel source. Is it worth my time to rebuild this lantern or should I look for a better specimen? Thank you!
