- First Name
- Donald
- Last Name
- Diehl
- Member #
0745
- Ham/GMRS Callsign
- WRPN 506
Never use any container for drinking water that has had a petroleum product stored inside of it. Ever.There are two old steel cans that have been used for gasoline forever. Is it possible to clean one well enough to drink water out of? Asking for a friend that has cleaned iwith Dove and rinsed it several times.
If you can taste petroleum, you still have petroleum chemicals that are t good for you going into your body.Water cans are cheap.
It wouldn't be worth it to me. If I "had to" use my fuel cans, hot (boiling) soapy water after soaking in acetone to pull as much out as possible then I would filter it with my chemical water filter (ceramic).
Hopefully it wouldn't taste like crap.
Interesting... all of the WWII jerry cans I've seen for water have had 3 handles (except maybe some of the very early war ones, before the German 3 handle version was noticed). The ones I've seen were stamped "water" though, on the top or side.???? Even back in WWII the jerry cans were marked, and made different. Gas cans had 3 handles, water had one. Still true to this day with Sceptor, Wavian, and any other Gov't supplier. The coatings inside are also different. So with that said, I would just spray some Simple Green and water in there, shake it up and buy a Life Insurance Policy.
And if your water tastes sweet...itll make you stupid. Thats the lead.If you can taste petroleum, you still have petroleum chemicals that are t good for you going into your body.
Sure you can, heck, I bet some glasses in bars contain crap that is way worse than some fuel remnants...There are two old steel cans that have been used for gasoline forever. Is it possible to clean one well enough to drink water out of? Asking for a friend that has cleaned iwith Dove and rinsed it several times.
That’s hilarious!Sure you can, heck, I bet some glasses in bars contain crap that is way worse than some fuel remnants...
I could write something like
"no retard will tell me where I have to store water"
or so but your friend probably should get something else to drink from...
