CB interference
Roger352
, Cornwall PL17 , United Kingdom
Roger
Smith
My CB aerial is on the back of my vehicle. I have new led work lights to fit which will be placed very close to the CB aerial will this cause any interference to the CB?.
RockyMountaineer
Laramie, WY, USA
Mathew
Threadgill
N5MST
Depends. If you use good quality wire and ground everything properly most likely not. But you won't know until you try.
Sent from my XT1585 using Tapatalk
Flipper
Florida
F
It will also depend on the quality of the voltage regulator in the lights
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
Put it all together and do some reception tests. The lights shouldn't make any "noticeable" reduction in transmission performance. Once you figure out if you are having reception interference we can go from there. There are ways to address these things.
Reactions: Roger352
