Having purchased a number of things from Front Runner before (including a drawer system and accessories) I can confirm the quality, however… not cheap.Front Runner makes a great rack set-up with accessory tray and stainless steel table that mounts under the rack. It can be installed sideways or to the rear depending on how the rear hatch on your rig opens. Make sure you get the rubber inserts that go in the slots at the bottom of the rack and nearly eliminate all noise. I also put weather stripping between the folded legs and the bottom of the table and now it make no noise.
I have a very similar setup. The table stores nicely at the bottom of my trailer....it's hidden under a tablecloth.I hemmed and hawed about a nice table (K9, Snow Peak, etc.) to replace my roll-top, but in the end I spent $40 on a 2'x4' plastic folding table that fits nicely in the rig and is a solid surface when set up. I like that it's stored out of the dust and mud so it's clean enough to use right away. It lacks the overlander style, but I can see past that for now.
This is awesomeeeeee!
I have the plastic 2x4' folding table as well. I like that it has adjustable legs, cleans up easily and packs inside nicely. It was $29!I hemmed and hawed about a nice table (K9, Snow Peak, etc.) to replace my roll-top, but in the end I spent $40 on a 2'x4' plastic folding table that fits nicely in the rig and is a solid surface when set up. I like that it's stored out of the dust and mud so it's clean enough to use right away. It lacks the overlander style, but I can see past that for now.
Just to be specific. I have a 2013 LR4, but I think the rear cargo storage area is exactly the same on the LR3. The area where the table sits is where the factory cargo pull cover would go, and I think that stayed the same.That's pretty awesome that it makes a perfect shelf in your LR3.
