bulletpoint mount question
wildcat
houston, texas
Neil
Young
is the system compatible with ram mounts? bulltpoint shows a 20mm ball. my ram balls measure out 23-24mm. can i put my ram phone mount on the bulletpoint ball mount?
MrWilsonWJ
Kennewick, WA
Dustin
Wilson
You will probably need to get one of the adapters to switch to the different size balls, Ram, Bulletpoint or amazon should have them. I use a lot of the Bulletpoint mounts and I think they are great, but have run into the same problem with different sized balls and had to adapt to use other brands attachments.
Reactions: wildcat
