Best Overland Rig for a Beginner?
michaelcarlos
USA
michael
carlos
Hey guys,
I'm a beginner in overlanding and in the process of purchasing my first rig. I need it to be dependable, capable, and not terribly expensive. I've been mulling over models such as the Toyota 4Runner, Jeep Wrangler, or even a vintage Land Cruiser. My big objective is weekend adventures with a little bit of off-road, but nothing hard core—trails, camping, and traveling.
A few questions for all the seasoned people here:
What is the greatest affordable overland vehicle for an newbie?
Are there essential upgrades/modifications that I need to address first?
Any significant reliability issues that I should be aware of?
I'd love to hear from those who've assembled their rigs from scratch. Did you begin with a entry-level configuration and build up over time, or go full bore right from the beginning? And if there are any particular gear suggestions (roof racks, recovery equipment, etc.), I'm all ears!
In preparing your rig, also think of power management solutions such as solar panels or battery systems. Similar to What Is Power BI, a software that efficiently analyzes and visualizes data, having the appropriate gear and setup guarantees a hassle-free and well-informed overlanding adventure. Begin simple, prioritize basics, and progress incrementally as you become more experienced.
Thanks in advance for your input!
Regards
michael
K12
Trail Blazer III
6,000
Canyon County, Idaho, United States
Beau
K12
Air Force
Hey guys,
Regards
michael
There is no perfect one size fits all answer, so you have a loaded question here. What works for me may not work for you and vicevsera. All of the options you lusted are good choices. The best thing you can do is find a reliable vehicle that you like then get out there and start with the vehicle water and food. sleep in the vehicle or bring a ground tent with you. the more you go the more you learn. you see what you NEED and the QOL, stuff that makes the trips a little more enjoyable. That may include RTT, rack, awning, slide out kitchen, etc. As for vehicle mods if you arent doing anything crazy some.mods arent neccessary, at the minimum having decent size AT/MT tires (33s should be olenty for most trails). again you learn as you go what you want to have in modifying the vehicle as well.
The Deputy
Michigan
Brian
Allison
Affordable is subjective. What is affordable to me...may not be too you or vice versa. And typically, you either pay on the front side or on the back side...paying for a well maintained newer vehicle or bringing an older one back to dependability status. Is the vehicle going to be primary or secondary?
Are you planning on sleeping inside, RTT or ground tent?
1) Vehicle. A Wangler is a tough vehicle to sleep inside, the Toyotas you mentioned are adequate. But, all three would fit the bill for a newbie.
2) Upgrades/mods. Keep it simple at first, basic cooking and sleeping equipment and build slowly from there.
3) Reliability. This is gained by preventive maintenance and staying on top of your rig. And knowing the basics for field repairs.
4) Build. My first build evolved slowly and changed dramatically along the way. Second build was more purposely built, learning from first. Both of my builds would be considered low-tech. And l carry the bare minimun, less is definitely more. Extra weight, clutter and useless gimmicks...only add to expense and wear and tear on vehicle.
5) Auxiliary power source. Have a duel battery set up. One for running fridge (which is a recent purchase, since carrying med supplies are necessary) and secondary interior lighting and the other battery for starting engine. Entertained getting solar, but now there are other options like the Jackery 3000. Good for about 3 days off grid. So, if you have a Jackery and second battery, you're good for about 4 days.
Edit: It's not a bad idea to just watch overlanding videos. Most start out just like you.
Good luck, and welcome to the board.
DharmaBumOverland
Creator III
1,739
Scottsdale, Maricopa County, Arizona, United States
Andrew
Richard
I’ll respond with some of the same sentiment as posted above
Affordable is relative, but an older generation Toyota would likely fit the bill.
The most important part aside from that is having 4WD and being reliable, it can be largely a battle of brand support after that. Jeep and Toyota do have a large array of aftermarket support. I’ve got a 3rd Gen Tundra to maximize interior space for a growing family and to be able to tow during harvest season if needed
Camping for the next few years for myself will be about introducing my 4 year old to the outdoors so I’m in a similar situation to you with weekend trips with mild off-road conditions
Number 1 priority after reliability for me is rated recovery points and gear from reliable brand like ARB and Factor 55. I’ll include a full size shovel here as well
Second priority was AT tires that still handle well on pavement as this is and always will be my daily driver. I went slightly larger then stock to try to keep everything as close to factory as possible. Means of airing down and airing back up to go with this, I use ARB to air down and Viair to air back up
Third was auxiliary lighting but that was almost more for work (dark drives in agricultural country) then off-roading so I added some ditch lights to give me more of a heads up for 4 legged critters
I’ve camped since I was old enough to so I’ve always had the gear on hand, and after the first two points that’s all you really need
Being a daily driver for me means everything loaded into totes and secured in the truck bed. I’d prefer to not have the cost and weight addition of a RTT so ground tent will be my solution (or no tent on occasion since I live in AZ)
A bed rack to mount traction boards and an awning, replacing bumpers, skid plates, another light bar and a winch would all be on the list for “someday additions” but to accomplish the goal of exploring backroads and camping with the kiddo my truck as it stands (AT tires, recovery gear, and camping gear in totes) will be plenty sufficient. If you’re traveling in a group low cost handheld radios can be very handy
rgallant
British Columbia
Richard
Gallant
VE7REJ
RCAC (Reserve) 75-00
To add to the information overload, I have overlanded in everything from an 80's Honda Accord to my current LR Discovery II. I covered 100's of miles of FSR's off road in that little Honda fishing and camping.
The best advice I can give you is:
  • No matter what you buy have a pre-purchase inspection done at a competent mechanic.
  • Buy as close to stock as possible - buying a "built" rig could be a significant can of worms
  • Vintage is nice but parts and service can be a problem
  • Decide what you can reasonably afford then research known issues before deciding
Finally, start simple, leave the truck alone no mods just drive it, get to know it. Stay on good FSR's and avoid situations where you may need a recovery - use your head basically.
Camping gear is simple, a basic Coleman stove, Lantern, led light cellphone battery pack, and ground tent used gear is fine. Sleeping bag and sleeping pad.
A cooler will do to start
That will get you going for simple overnight trips and even 2 or 3 nighters, from there you can start adding camping gear.
Recovery gear is a tough thing:
  • a good recovery strap
  • kinetic rope
  • soft shackles,
  • front and rear recovery points
  • SHOVEL - yes is caps but is a requirement
  • good work gloves
  • tire repair kit
Learn how to use a kinetic rope it is not attach and floor it, it is a slow steady pull. Winches are not a requirement, they are nice but if you use your head you find they get very little use.
Reactions: DharmaBumOverland
Frank1972
North Carolina
Kevin
Sharpe
U.S. Air Force
The best overland vehicle is the one you have now. You can spend your whole life chasing the "perfect" rig. Your current car/truck might not be the most trail capable but it can get you to the woods and let you start enjoy camping. After you have done this for a while, you will learn what works and does not work for you and you will start to answer your own questions.
When I first got into overlanding, I started with my stock Ford F-150. It is my daily driver and general work truck for around the house. As I got more experience, I slowly started making upgrades -- skid plates, tires, suspension and soon some lights. But I started with just getting out there and enjoying the experience.
Reactions: rgallant
MesaJohn
Grand Mesa, CO, USA
Lane
I'm brand new here, but I opted for an FJ Cruiser. There are still FJ's out there that have 100k or less miles and are very affordable and come with some nice capability.
Yep, I bought an FJ for $16k and flippin love it! I am not freaked about 'pin stripping' an $80k rig.
tjZ06
Las Vegas/Palo Alto
mynameisntallowed
Adams
Take a look at this thread I started: If you're going to ask "what vehicle is best..."
I don't mean that as a knock, or to be snide, and I know you covered *some* of the questions there. Still, we need to know a lot more about your budget and needs to really narrow it down. "Affordable" to one guy is what the next guy owes on his house.
You mentioned Wranglers, so if they are in your budget a JK or JL Rubicon is hard to argue as the best single Overland platform (as well as Gladiators). Even more so if your version of Overlanding includes tougher trails. JKs and JLs have their known issues, but all are pretty easy to avoid or address. Things like don't get a 3.8 JK, don't get a Ecodiesel JL, keep an eye on the oil cooler on 3.6s for leaks. 2.0Ts have overheating problems (and so do the diesels). Outside of that there are a million ways to go, and budget will be a big dictator as well as the other factors I highlight in that thread.
-TJ
